This event indicates that a MPLS interface request has failed.
The exact remedy is dependant on the particular situation; but the problem may be resolved by reducing the amount of resouces used by the system.
Error
Vlan I3 error: current event = %if_event_str% interface instance = %if_instance%. desc. = %cause_str%. Return code = %retcode%
| Name | Type |
| if_event_str | String |
| if_instance | uInt32 |
| retcode | sInt |
| cause_str | String |
